3.1 question
  • 3.1 question
    I have a low mileage(30k) 3.1 from a 1993 Lumina. I also have a 1998 Skylark 3.1 with a broken camshaft. Can I put the '93 engine in the '98 Buick? I am more than willing to make modifications if this is remotely possible. I only have the '93 engine, no computer or harness.
    Thanks for any info.
    -Fred
    No, as the 93 engine does not have all the sensors that the 98 PCM is looking for. You would also be looking at a decrease in power of around 20hp. Its always easier to put a newer engine in an old car, but its near impossible (and depending on the state, illegal) to put an older engine in a newer car.
      You could build a "hybrid" by putting the whole top end from the '98 engine onto the 93block and bolting that in, you'll have a check engine light because the 93 engine does not have a camshaft sensor or the 24x trigger on the crank pully.
      you'd probably have to order custom length pushrods as well..
      I think it would be easier just to drop a few hundred bucks and pick up another 3100 from a junk yard and drop that in.. it would run alot better and save all kinds of time.
