connecting rod ?
  • connecting rod ?
    ok when u put the end caps on the rods correctly, are the insets for the tangs on the bearings supposed to be on the same sides or opposing sides per se. are they supposed to be offset but on the same side as the conn rod bolt is.
    Same.
    Look on the rod cap and rod and you should see a number. The numbers line up and will tell you orientation of the caps - making the tabs on the same side, numbers on the other.
      ko...got it figured out, thanks
