3900 crankshaft flange
  • 3900 crankshaft flange
    Hey guys...I would like to know how far in, or out, the crankshaft flange (that a flywheel or flex plate bolts to) is from the engine block (the surface that a transmission would mate to). Is it true that all 60 degree V6s share this same dimension? I'm having to design a custom flywheel/pressure plate for a project...
    Thanks in advance
    '89 Buick Reatta. Supercharged 3800 LN3. Series II L67/ 6 speed manual in progress...
    It's the same
      Thanks Mr. Upson, we meet again. Do you happen to have that measurment?
        No, maybe someone here has access to an engine and can take a measurement for you, I'm to far away from home. You should probably start with a stock flywheel measurement though instead of a measurement point relative to the flange unless you are using an adaptor plate.
