3.4pr swap into 2.5 S-10
  • 3.4pr swap into 2.5 S-10
    Just wondering on the complexity of a 3.4pr swap into a 1988 2.5 5 spd S-10. Also maybe swapping 3400 piston,3500 heads ,intake and different ECM.
    Well about the only thing that will work is the transmission. Otherwise pretty much everything else is different. Are you planning on using a RWD block from a Camaro or using a 3400 motor?
      Well I was thinking about a camaro block with 3400 pistons, heads and intake. I was looking at an S10 for my son but it has problems. I think I got this in the wrong catagory, I didn't see the swap section ,sorry. Well guess I'll keep looking for a S10, no deal is better than a bad deal.
        Well it is a nice swap but does have its difficulties. If you are experienced with swaps it should be fairly straight forward for you. It would be easier to start with a 2.8L S-10 if possible.
