for a while now i've been having some knock/piston rattle. and i've tried some solutions with no results yet. my ks circuitry is right on, (volt reference, and sensor resistance), so there is no problem there. I have not thrown any codes either. I've checked the fuel pressure, it rides at 45psi idle. BTW: this is an 03 3400 from an impala, with about 17k miles. I've tried switching a gas station once, but still did it some, (but i should try a different station yet again) The condition started, as when i would be in 4th or 5th gear at low rpm, and hit the throttle suddenly, or even somwhat slowly, and would have affirmative piston rattle. it will usually NOT give me any fuss if i slowly push the throttle down to WOT. I have mild mods, intake exhaust, udp, tuned chip by a v6z24 member, (using multech 2 injectors also). TODAY, it was really bad, i was hearing some knock in 3rd acceleration, and 2nd gear WOT, above 4k rpm, ? at this point i dont know of what else there is for me to try. (tomorrow i will pick up a different ks, and one from a 3.4 iron head, and try those). Otherwise i'm looking for suggestions, as im not sure what to do, besides 1. different gas station 2. colder plugs? 3. possibility of carbon build up? One time there was no knock, was when i added 3 gal of 91 oct, and some lucas octane boost, and at that time there was no piston rattle. I also asked about using a AFPR, to allow more fuel in during the pulse width, but i was told that was not a problem... Any suggestions appretiated much.
thanks
cody
thanks
cody
