Secondary AIR System on 3400...
  • Secondary AIR System on 3400...
    Is it really neccessary and/or can it be removed easily? I am installing a 3400 from a 2000 Lumina into a Fiero and I am curious as to what I can do with this system. The engine did not come with the associated electric pump so rather than junkyard it I am checking out the option to remove it.
    Any suggestions?
    - Ben
    IIRC that system injects air into two of the exhaust ports on each head. If so, just pull the fittings out and plug the holes with 1/2-20 set screws. I believe that I used 1" long ones on the engine I had here. Quick, easy and cheap. Too bad everything else in life isn't this easy.
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
      Awesome... thanks for the reply.
      Do you know of anyway to look up ECMs by the service numbers or other info on the stickers? I have an engine, transmission, ecm and harness that I bought but I don't know what car it came out of...
      - Ben
