cam base circle for a 3400 motor
  • cam base circle for a 3400 motor
    anyone know what the base circle is???
    3.4L camaro some goodies
    what it is or what the diameter is?
      diameter, sorry :P
        anybody?
          Camshaft
          Lobe Lift
          - Int and Exh: 6.9263 mm (.2727 in)
          Journal Diameter: 47.45 -47.48mm
          Bearing Bore Diameter -Front and Rear: 51.03 - 51.08 mm
          Bearing Bore Dia.- Middle #2 and #3: 50.77 - 50.82 mm
          Bearing I.D. : 47.523 - 47.549 mm
          Journal Clearance: .026 - .101 mm
          Journal Runout - Max: .025 mm
          Directly off of the site info...
            That isnt the base circle diameter though brad.
              How accurate do you need? I could run out and measure one with a dial caliper. If you need it more accurate, I would need to dig out my micrometer set.
              Marty
              '99 Z-28 - Weekend Driver
              '84 X-11 - Time and Money Pit
              Quote of the week:
              Originally posted by Aaron
                Hmm... good point. I wonder if it's on my cam spec card. I'll have to see... and it isn't.
                  Hmm... good point. I wonder if it's on my cam spec card. Nope.
                    I measured my '98 3100 cam with a dial caliper, and came up with a lobe base circle diameter of 32.69mm, and lobe height of 39.67mm, which comes out to 6.98mm lift, close to Brad's factory specs.
                    Marty
                    Quote of the week:
                      thank ya
