Blocking the AIR ports on a 3x00
  • Blocking the AIR ports on a 3x00
    I want to block off the ports coming out of the heads on cylinders 1/3 and 2/4 on my 2000 alero 3400. Don't worry about emissions or anything, as it is going into a Fiero that doesn't see the street very often anyways. I figured somone on here either made caps, or knew where I could find them. BTW, these are GM's excuse to an AIR injection setup right?
    Justin
    1988 Fiero Formula - 3400sfi with an intercooled 60trim, Haltech, water/meth
    1990 Mitsu Eclipse GSX - parted out
    1991 Galant VR4 #108/2000 - Slammed sedan, built everything
    1995 Kawi Ninja zx7r
    1992 S10 4x4 - lowered/bagged, the dd
    2004 450R MX quad
    Justin
    Easy to do Justin.... just remove the fittings from the heads and replace them with 1/2-20 x 1" set screws, preferably stainless steel if you can find them. I believe it's a CA emissions engine.
    MinusOne - 3100 - 4T60E
    '79 MGB - LZ9 - T5
    http://www.tcemotorsports.com
      It was also for Northeast emissions as well. The AIR system is only "on" for 2 minutes when you start the engine cold. So performance wise it doesn't affect anything.
      Your local OBDII moderator
      2000 Grand Am GT w/ WOT parts
        cool, thank you both... I figured they really weren't anything special.... just looks good to the gov't.
        2004 450R MX quad
          I did something rather different but still the same idea.
            That looks good
