OBDII manual swap
  • OBDII manual swap
    Going to swap a 5 speed manual into my 96 Grand prix 3100.... I have all the wiring figured out for the clutch safety switch, reverse lights, speed sensor, saftey switch for starter, and the load switch that is on the clutch...
    but my question is... with swapping out the 4T60-E for the manual.. would i have to change anything in the ECM? since there will be some wires that are not going to be used... like the shift solenoid wires... will that throw a code? Wanting this to be a clean swap.. so im doing as much research as I can...
    *1988 GMC S15 sierra pickup, 2.5L "Iron Duke" I4, 25-30mpg
    *1997 Mitsubishi Eclipse RS, 2.0L "420a" I4, 30-36mpg
    *1997 Bayliner 1750 capri, 3.0L "mercruiser" I4 inboard/outboard
    *1999 Go-ped Sport, 1.2hp "G23LH" I1, 25mpl (100mpg),
    (soon to be a 5hp G23LH/CY29RC hybrid), Autolite 255, Walbro carb,
    25:1 Castro full sythetic oil, 93 octane
    Contact heavywoody here on the site. He did a 5-spd swap into his 96 Beretta. IIRC, he didn't do anything to the PCM.
      Cool, thanks. I sent him a PM...
        I thought you had to config the PCM for it to work right? Seems like you would have to, becuase as soon as the PCM didn't detect the auto shifting it should start tossing codes.
        SpudFiles
        Theopia
        Enjoy life online.
          I swapped a 5 speed into my then 3100 equipped 95 beretta and i didn't have to mess with the ecu at all.
          95 Z26 3400/OBDII/GETRAG
            I think woody's car was a 95. I'm running a 5 speed with OBD II and my SES light is on because of the pcm not snsing shift solenoids.
              not only will the pcm throw codes, but its going to derate the engine (pull timing to limit power). the best thing to do would be to get a power tuner and disable the auto trans functions.
                Because it's OBD-II you have to turn all the tranny fault codes off in the ECM and reset your rev limiters. It can be done without getting codes, it's just a pain in the ass ironing them all out.
