4t60-e tcc solenoid replaced still problems
  • 4t60-e tcc solenoid replaced still problems
    ok we replaced the tcc solenoid on a 96 4t600-e cause it was throwing the code for it. needless to say after all the crap of ripping half the car apart it still throws the code for the tcc lockup solenoid even though theres a brand new one in there. could there be a problem with the computer or the vehicle speed sensor. any help is appreciated as i want to resolve this problem.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
    515 515 lift 112 lsa
    Did you disconnect the battery for a long time or clear the code?
      yep was unhooked for the better part of 4 hours and hooked my code scanner up to it. if it help it seems like its stuck in 3rd or some higher gear than first. this all started when my friend was coming off the highway. he started to slow down to exit and he said every light on the dash came on, and then when he stopped the car and put it in park it wont let you take it out. example step on the brake to move the gear lever no workie. now the abs and brake lights are on too.
      99 Grand Am GT
        What kind of vehicle is this exactly. I can ask the tranny tech I work with today. Give me the Vin# and I can go from there.
        I also need to know what else the car is doing too. Is the battery charged (no less than 12.4V), does the car start, does the car run? We need to rule out the engine, can't remember if the car has a ECM or a PCM; there is a difference in the two.
        mexican food gives me the sh#t's...
          95 buick skylark 3100. car starts runs and does everything normaly. we got a spare computer to try that route. engine crap seems to be all normal. the only code we got we p1864.
          99 Grand Am GT
