flywheel help needed
  • flywheel help needed
    i got a neutrally balanced getrag 282 flywheel and have heard heresay that it is the same as the 284 flywheel.
    this is what i know: the tooth count is the same, the crank bolt pattern and the pressure plate bolt pattern is the same.
    what else do i need to know and i have both flywheels side by side if u guys need pics.
    what else do i need to know about them to see if they can swap over. i want to be as sure as possible b/c it is a $400 aluminum flywheel and i cannot get a refund if i install it.
    i think they'd work then lol, check the thickness of each i am sure they'll be close if so ur fine
