Which gear ratios???
  • Which gear ratios???
    I'm a little confusied on what 5 speed gear ratios/FDRs are in a couple of different cars. A 91 Sunbird 2.0 and a 94 Cavalier RS 3.1. I thought they were all the same. Help! Thanks.
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    RE: Which gear ratios???
    well, the 3.1l is as follows
    V6 Getrag All years J and L body 1st 3.50 2nd 2.05 3rd 1.38 4th 0.94 5th 0.72 Axle 3.61
    the sunbird 2.0l im not sure of. they use an isuzu 5 speed.
      Ok, great. Got that one down. Now I just wonder what my lil bird had. They both had the same top gear cruise RPM. I know with different ratios that can be achieved w/o having the same tranny. I just figured GM would use the same tranny. HA! Silly me!
      Andy
        na the isuzu is cheaper to build because it doesnt need to be as strong as the v6 tranny.
          ahhhh I see.... it's starting to make sence. i'll be sure not to use that one should i 5 spd swap. now i just need those ratios--out of curiousity.
          Andy
            Your bird probably had the 3.58 FDR. As far as I've found I've only ever turned up with 3 different FDR's for the Isuzu MK7/MR3 tranny.
            3.58 seem used mostly by J-body cars
            3.83 i've found in the Isuzu Stylus
            4.10 you'd find in a Geo Storm GSi... not sure what the lower models had.
            It's also said that the MJ1 (96-99 2.4L Cav 5spd) used a 3.91, but i'm not real sure about that.
            97 Cavalier RS
            3400, Isuzu MK7
              What about the other 5 gears?
              Andy
                From V6z24.com
                Isuzu 5 Speed Manual (RPO: MK7)
                1st - 3.91
                2nd - 2.18
                3rd - 1.45
                4th - 1.03
                5th - 0.74
                97 Cavalier RS
                3400, Isuzu MK7
                  turbo 2.0 sunbirds use a getrag also.
                  Stephanie
                  92 GTZ ~SupermoddedW41GTZ~
                    the 2.0l turbo does use a getrag. im not sure of the ratios in it though, i cant get an answer out of anyone on that. i guess when i put the lsd into my buddies 90 turbo bird, ill have to figure them out.
                      i figure the turbo's use the same at the V6's. it's close enough to the torque of the older 3.1.
                      Andy
                        yea but the torque curve on those motors is way different. at low rpm, you have a serious lack of torque, and when the boost hits, the torque curve basicly goes straight up. the v6 has a way flatter torque curve.
                          dosen't matter what the torque curve is. it the peak that the tranny will see. it's only about 15 ft.lbs.
                          Andy
                            i was reffering to the gear ratios. if the turbo 4 cyl had the same gearing that the v6 did, it would be an absolute dog till about 3k rpm when the turbo spooled, then would take off like a rocket. it deffinitly doesnt do that, it goes not to bad before it hits boost. and i know his sits about 2800rpm at 100km/h, my v6 sits around 2200.
                              that's what I don't get. the 94 cav V6 and my 91 2.0 bird cruised at the same RPM. that's why i thought they all had the same thing. -shrug- oh well. it's not that important. like i said, just curiousity. thanks for all your help guys!
                              Andy
