4t60 problem
  • 4t60 problem
    my friend has a 90 grandprix with 3.1 and a 4t60 and the other day he said the tranny stoped working
    i checked it out and heres what i know
    the engine is fine purrs like a kitten
    the tranny fluid is fine and at the right level
    it doesnt matter what position the gear range selector is in the motor just revs like its in park
    when gear selector is moved there is no load placed on the engine
    (you know like when you put it in gear you can feel it jerk a bit) but it does come out of park
    the gear range selector linkage is connected
    the engine will only start with the gear range selector in P/N
    there is no grinding noise oar anything when the engine is revved
    (as there would be if the convertor broke off the flex plate or if the output shaft had snapped)
    he said there was a cluck when it happened
    my theory is that the trans itself is still intact but the convertor is messed up or that the chain has broken or something
    we are going to start taking it apart and check a few things but thats not going to be for atleast a week
    has anyone ever had anything like this happen or even heard of it
    i am hoping to find out if its worth messing with to see what the problem is
    i dont want to have to take it apart if its not necessary
    I Like V660s
    Does Chevy make beer
    ~Jayme~
    Maybe a clutch pack hub teeth stripped?
    2004 Grand Am GT 3400 ... I had the right to remain silent, I just didn't have the ability.(Ron White)
      Thats basically what just happened to mine. My fluid pump destroyed itself and the gears just stopped working. I had some noises while running though, but same symptoms of no load on the motor
      Robby Whitesell
      2006 Pontiac G6 GT
      1985 Toyota Pickup DLX
