oops broke the trans
  • oops broke the trans
    well i am sitting here at my computer looking at some peices of the final drive cover. and parts of a spider gear out of my cutlass that i picked up off of the ground alittle while ago..... needless to say it dosent move any more... looks like ill be putting a final drive in this weekend...... i have had the trans out 3 times but i have never put a final drive in without having the trans out... it dosent look to fun.. but not to teribably hard either...
    1994 Cutlass Supreme Convertible 3.4 DOHC
    1969 Oldsmobile 442
    1997 Chevy Tahoe
    http://members.cardomain.com/mperkins442
    also do any body know of a place the makes a limited slip diff for the 4t60e...... i might as well concider this sence i have to replace it any way... if i rember corectly there was a place that made them... dut i dont rember who or where
    1969 Oldsmobile 442
    1997 Chevy Tahoe
      I feel your pain. That's why I posetd earlier about the 65. Need tougher bottoms and more gear. I want to know if parts are compatible.
        Heh,
        I certianly feel your pain. I'm looking at picking up the LSD for the same reason.
        I believe you were searchin for: http://www.domesticperformance.com/p...roducts_id=282
        Out of morbid curiousity, did you snap the main rod in the carrier housing? This is what happened to me. It occured right where a pin through this rod holds the entire assembly in the carrier housing. IMHO, this seems kinda like poor design... But then again, I'm no mechanical engineer. Good Luck![/url]
        Regards,
        Todd E. Johnson
          no i actually broke one of the spider gears into 3 picses and sent that through the casing
          1969 Oldsmobile 442
          1997 Chevy Tahoe
            If you are looking for a limited slip, contact "pontiacjeff" on this site. He runs/owns Engineered Performance and can do the conversion. You should also talk to him about a 3.33 diff for better overall gearing.
              well i got my new final drive in today...... that was a long ass job... but well worth it cuz now i have my car back......
              1969 Oldsmobile 442
              1997 Chevy Tahoe
