02 GA 4T45E Transmission Issues
  • 02 GA 4T45E Transmission Issues
    Well I think the transmission might have kicked it. A few weeks back the transmission started having issues. When shifting from 3rd to 4th the RPMS would climb to like 2500 RPM before shifting gears. I would have to back off acceleration and get back into it for it to shift ok. Also at one point I lost 1st and reverse for a few hours but they ended up coming back. Yesterday I lost reverse completely. The transmission will lock when I put in reverse but do nothing. Also 1st through drive work but they feel a little stuck when trying to use them. Has anyone had issues like this before?
    "Living is doing everything you want to do and dying is everything else"
    Check the fluid level.
    Grand Prix trans with 3.33FDR
      I did. It was 6 quarts to high. When I pulled the plug it just started putting out of the transmission. Now the torque converter is rattling after doing that. I got my first and reverse to release.
      Sent from my SCH-I545 using Tapatalk
        How is that even possible. . .Are you sure?
          Yeah. I must of overfilled it when I did a filter and oil change a few weeks back. I filled a 5 quart jug and lost another quart on the floor.
            Wow, overfilling is never been a problem for me. Just had a few problems do to not filling it enough though. First time ever.
