Converter Stall Speed
  • Converter Stall Speed
    I was wondering if anyone knew the stall speed of the converter from a '94 Grand Am 3100 4T60E
    Lorenzo
    crappy, I belive its 1800 like the montes
    1995 Monte Carlo LS
    3400 SFI 60v6
      1800?!?!?! I thought Chevy at least would get the same as like the Olds or pontiac w-bodies. My car's 2600
      Brian
      3400 SFI V6, 4T60e
        nope, Ill be stealing mine out of a olds for the rebuild, someone told me theres a 2800 available in something, Ill have to ask that person again what it was though
        1995 Monte Carlo LS
        3400 SFI 60v6
          1800 doesn't suprise me at all. Although I'm not sure, I was told that mine was like 1898 or something like that...I don't know why they wouldn't just say its a 1900 though if it is.
          Shawn
          99 Grand Prix GT
            btw that 2800 stall comes from a '90 Cutlass, I have a hookup that can get them for about $100 if anyone wants one.
            1995 Monte Carlo LS
            3400 SFI 60v6
              Is that from a '90 quad4 or from a 3.1? And if it is from a 3.1 is that specification the same for '89 2.8/3.1?
              Lorenzo
                not sure, Ill have to check, Ill let you know
                Im betting its the quad4 becasue that thing revved so high
                1995 Monte Carlo LS
                3400 SFI 60v6
                  Quad or not...they should adapt to the 4t60(e). The TCLock up meterial is different though.
                  YOu can take advantage of a stalled converter with gears. No sence in runing 2500 stall on a 3.05 gear on a heavy car. The theory of stalled converter is to get as close to the engines peak tq. for better takeoffs. Pass the engines tq with a over stalled converter and performance will suffer alot. High stall with low gears(3.05) and on a heavy car and it will feel "jerky" or harsh. Not to mention the torque converter will heat up the trans oil faster. Just a caution.
                    Yep, im well aware of that, I want a 2800 stall converter to complement my t65 build which will include 3.69 gearing. With a 3400 that should put me right where I want to be power wise at the launch. The trick will be learning how todo it with out braking the tires loose like mad. I still need alot of pratice launching
                    1995 Monte Carlo LS
                    3400 SFI 60v6
                      what about the 4t40 or the 4t45, in the newer N bodys? I've got the 3.29 factory gear ratio. would that stall be to high?
                      2002 Pontiac GrandAm GT1
                      3400 v6
                      TOG headers
                      RSM 62MM T-body
                      FFP underdrive pulley
                      GRANATELLI MAF
                      Ported upper intake
                      MSD DIS 4 ignition box
                      MSD Wires and coils (pending)
                      Venom high flow fuel pump (pending)
