Any other 284's
  • Any other 284's
    What cars other than the early 90's W-body DOHC came with a Getrag 284?
    None...
      there are other manual options for w-bodies besides the 282 and 284, it just depends on the power your looking to put through it
      1995 Monte Carlo LS
      3400 SFI 60v6
        I think the Masarati TC by Chrysler and the Dodge Spirit RT/Turbo also gad a manual tranny with the same guts as the 284, but with the Chrysler designed case. I don't think any parts would interchange with the GM version, however.
        Marty
        '99 Z-28 - Weekend Driver
        '84 X-11 - Time and Money Pit
        Quote of the week:
        Originally posted by Aaron
          How much can the 284 handle, and are there any other manuals that will fit on a 3.4 DOHC?
            ive heard of someone slaping a 284 on a s/c 3.8L running 400hp and it took the power just fine.
            Jake
              Ive heard 2 sides to that, Ive heard the 284 taking up to 400hp then ive also heard it blowing up every 6 months with more than 350hp. The 282 doesnt like too much above 320 but at least it is servicable. Keep in mind that if you trash a 284 it is not self-servicable and its expensive to repair.
              Im guessing the varied reports I get on the longevity of the 284 is highly dependant upon the driver. I like to beat the hell out of my car. You can have a lot of power and be careulf and your trans will last. Or you can beat it up and it will last only for a little while. I want to go into autocross, I need a manual option that can take a beating and ask for more.
              1995 Monte Carlo LS
              3400 SFI 60v6
                My 284 has been handling 210hp and 215lb/ft for 176,xxx miles. Just make sure you use the GM transmission fluid, nothing else.
                --Rob
                  I want to make at least 350whp(I'm gonna need a little help doing it) , don't care how so long as I don't use any giggle gas. I'm going to rebuild my transmission any ways, If parts were to fail what would they be?
                    I hear the clutch goes the most, if thats the case then it may just be the driver and not the transmission
                    1995 Monte Carlo LS
                    3400 SFI 60v6
                      Marty
                      the Spirit R/T actually got the Getrag A568; the TC was the only one to get the Getrag 284, and only 501 of them at that.
                      '91 Cutlass Supreme sedan - 3.1 Intercooled Turbo / Getrag HM-282 5-speed - 13psi / lightly modded
                      '98 Regal GS - 3800 Series II Supercharged/HM-4T65E-HD - 180* T-stat, otherwise stock
                      GM W-body Forums
