'92 4t60e tranny pull
  • '92 4t60e tranny pull
    Ok,I've finally gotten all of the bolts out of the car so that I have the sub frame dropped...bolts are out of the bell housing,engine to tranny mount is undone,now,do I have to totally drop the whole sub frame to get the tranny out? it doesn't seem like it's wanting to move,there is a space between the bell housing and the engine,what am I missing here? This is my first front wheel drive job,I have done plenty of rear wheel pulls...both axles are pulled,there isn't anything else that I can see that needs to be removed to get this thing out,any and all suggestions are welcome...just need a little help.. thanks in advance...
    There is a bracket between the tranny and engine at the diff housing on the passenger side. The way the engine/trans is supported I don't see a way to remove it without pulling the subframe unless you went out the top. Hope this helps.
      There is one bolt going from the engine to the trans.
      Not the same trans, but same concept:
        thanks,guys,I was "hoping" not to have to totally drop the sub frame,and yes,I did get that back bolt...damn,this thing has been a pain in the ass,wish I'd have just paid the 400 bux to have it done,thanks again..
