Internal slave getrag (NVG) question...?
  • Internal slave getrag (NVG) question...?
    I upgraded to an internal slave getrag in my Fiero. Are the slave hard lines only secured by the rubber grommet bulkhead through the trans case? This is before I have attached the slave line to the rest of the system. They feel a bit loose, and I want to make sure this is normal.
    Thanks,
    Blake
    Thanks,
    Blake
    I know one line rotates freely. If your referring to the hydraulic throw out bearing. My HTOB wiggles slightly in the trans housing but it isn't bolted to the block yet. I'm sure the feed line will still have some will to pivot.
