Any 4t60e stall converters or lsd's?
  • #31
    i think a 95' grand am 2.3l tc would be perfect
    Model Code Motor and Platform, Differential Ratio, Sprocket Ratio, Final Drive Ratio, VSS Reluctor, Stall Speed
    grand am: 5PCW 2.3L Quad4 *3.29, 33/37, 3.69 29, 2363
    beretta: 5WFW 3100 L/N-Bodies *3.29, 37/33, 2.93, 29, 1630
    any opinions?
    • #32
      thats just changing some internal parts. If you want those parts too we have them instock good used.
      • #33
        whats the price on one with kevlar internals
        and anyone know if this would work?
        2.3 Quad4 N-Body 3.06, 33/37, 3.43, 29, 2095
        the diff ratio and sprocket ratio are different, would it work for me?
        • #34
          slinky i ran a 2095 in my purple car, made a little difference. winter imma run a 2363 stall with the 3.69's from the same grand am your talking about.. torque converter i dont believe change, every 4t60e converter will work on your car. if you change the gear ratio, youll need to tune the trans for the different ratios. use the 95 g/a trans with the 3.69's and the 2363 or run the 96 g/a trans with the 3.73's and 2363 converter.
          [COLOR="red"]1996 beretta z26, 3500 v6 currently awaiting my holset hx35 COLOR]
