abs speed sensor as vss?
  • abs speed sensor as vss?
    i know this is a crazy long shot but do u guys know how possiable it would to to use a abs spped sensor as a second vss. i need two and even if it wouldnt be to exact i just need the pcm to know wen the cars stopped and moving. the tranny is a nvg282 and the cars a 99z24 idk if any one has more knowledge or might know the tooth count on a 282?
    bump. anyone have any insite?
      Newer cars use the ABS system to run the speedo and stuff, so I don't see why it couldn't work... What is your goal with this?
        i need two vss inputs i because i have 2 pcms. one for engine one for gauges. i could splice the one but jw about another option.
          If you can change the speedometer constant in your tune, I don't see why not?
          Hell I might do this cause I think the VSS tone ring is busted in my 282... LOL
