F1 Racing Clutch/Flywheel kit from gripforce
  • Question : F1 Racing Clutch/Flywheel kit from gripforce
    F1 Racing Clutch/Flywheel kit from gripforce.com
    Anyone use or have experience with them?
    I have read both Great and terrible reviews?
    I know you get what you pay for and they cost less, just wondering if anyone has ever used one and how it felt/lasted?
    As of April 2
    Engine: 2006 SV6 3500 LX9
    Trans: 2002 Getrag F23 5speed
    Injectors: #36 GTPs
    TB: 65mm TCE
    Maf: 1999 3400 Montana.
    Beverages: Ice Cold CANADIAN.
    Guess No One has used this brand before?
    As of April 2
    Injectors: #36 GTPs
    TB: 65mm TCE
      What kind of incredible BHP/Tq numbers are you producing to use anything more than a stock clutch setup?
      -BMC.
      MG & MGB V6 + V8 Engine Conversion Shop
      1982 Chevrolet S10 long box with another L32 SFI!
      1980 MGB with Camaro L32 3.4L SFI V6
      2000 Venture 3400 (for her)
      Spitfire L32 3.4L
      "Experimentals"
      and more conversions all the time.
        3500 Turbo in a Car that originally had a 2.4 Dohc.
        As of April 2
        Injectors: #36 GTPs
        TB: 65mm TCE
          Have read that the disc is actually made by raybestos.
          Not sure if I should try em or not?
          As of April 2
          Injectors: #36 GTPs
          TB: 65mm TCE
            doooh, internet skip, double
            As of April 2
            Injectors: #36 GTPs
            TB: 65mm TCE
              I am this < --- > close to ordering this kit.
              I need at least something initially to piece my swap together and for $200 this will get me by?
              F1 Racing Stage 3 clutch kit is a direct factory replacement clutch kit and it's designed for those who seek the ultimate in clutch performance and reliability. F1 Racing clutch kit includes only the highest grade clutch components from the world's leading racing clutch manufacturers. The 6-puck copper ceramic (also known as MIBA) disc features 12 high-coefficient friction pads that are resistant to slippage and ensures long lasting life. The heavy-duty sprung center unit boasts heat treated springs and retainer rivets for the maximum power and durability. The F1 Racing pressure plate features special single diaphragm design to increase clamp load. It features induction hardened diaphragm, CNC machined castings, stronger drive straps and rivets. F1 Racing pressure plate provides smooth and precise feel with easy modulation. All F1 Racing pressure plate is load tested on a special testing tool for quality assurance.
              * This complete clutch kit includes: F1 Racing Heavy-Duty Pressure Plate
              * F1 Racing 'MIBA' Copper Ceramic 6-puck Disc (8-7/8", 14 spline)
              * Release Bearing
              * Alignment Tool
              * Installation Guide
              Horsepower Rating: 281 HP / Torque Capacity: 294 ft/lbs
              Gripforce offers the industry’s most comprehensive lineup of high-quality OE spec. new flywheels for passenger cars and light truck applications. Our OE spec. new flywheel is engineered and manufactured to O.E.M. specifications, using premium grade iron, new ring gears, and new dowel pins. To reduce vibration and maximize performance, each unit is dynamically balanced, backed by our comprehensive warranty, and priced competitively versus the cost of a resurfaced flywheel. Warranty costs and idle rack time are virtually eliminated.
              * Brand new flywheel requires NO core charge
              * Made from premium grade steel
              * Gripforce OE spec. flywheels work with every clutch kits including Exedy, ACT, Fidanza, Clutchmasters, and other OEM clutch kits
              * Flywheel weight: 21
              Retail Price: $ 844
              F1-82105R3-SS & 167500-AM #38
              As of April 2
              Injectors: #36 GTPs
              TB: 65mm TCE
                Wow, that's only $200? Where at? I know my clutch in the 91 slips from time to time as it is so stock isn't working out for me. Ceramic would rock, especially being pucked. I think I want to go with a 4 puck when I get one though. A lighter disc = easier on the synchros, and with a 284, anything easier on synchros is a good thing. Have you googled that clutch to find reviews on it yet?
                  Ya I googled, seems to be 50 50
                  some are extremely happy other are extremely unhappy lol.
                  After engine swap, the trans will be next, but I will need something to start so thinking to go with anything cheap at first.
                  As of April 2
                  Injectors: #36 GTPs
                  TB: 65mm TCE
