What year is your car?
Transmission Manuals!!
EW!!! Devil car!!! Ok, just the ECM is evil. OBD 1.5 as some call it. OBD 1 flash ECM w/ an OBD2 connector, which requires a dealer to read codes from it IIRC. I think Brians car is a 94, maybe you should talk to him about swapping backward to OBD1 w/ a 91-93 ECM setup if you decide to go the 5 speed route. Mine was a 91, so it was all straight forward since a 5 speed was available in 91 (93 was the last year for them).-60v6's 2nd Jon M.
Originally posted by pocket-rocketEW!!! Devil car!!! Ok, just the ECM is evil. OBD 1.5 as some call it. OBD 1 flash ECM w/ an OBD2 connector, which requires a dealer to read codes from it IIRC. I think Brians car is a 94, maybe you should talk to him about swapping backward to OBD1 w/ a 91-93 ECM setup if you decide to go the 5 speed route. Mine was a 91, so it was all straight forward since a 5 speed was available in 91 (93 was the last year for them).If you are driving a Chevy, everything else, is just a blur. 3.4 Carbon Footprint.
I know if you do too many one wheeled burnouts when turning corners, the pin that holds the two spider gears in comes out of the diff housing and tears up the case extension. Happened on both of my old autos. I don't remember how the pin is held in, maybe something wasn't tight, and the pin came out or something.-60v6's 2nd Jon M.
Originally posted by SappySE107You should go ahead and have parts from a 3.1 4T60 used to create a 3.73 FDR. Also, im pretty sure you can get better clutches/bands/whatever the hell is in the trans. You can also get an LSD for it.If you are driving a Chevy, everything else, is just a blur. 3.4 Carbon Footprint.
put the shift kit in it saves them, going to a larger front diff, 3.73will lower your transmissions strength.put the shift kit in it, i have one for sale brand new 40 +shipping its a trans go hardened pind and stuff.vrrrooooooooooooooooom i need new exhaust
Originally posted by 93vinxput the shift kit in it saves them, going to a larger front diff, 3.73will lower your transmissions strength.put the shift kit in it, i have one for sale brand new 40 +shipping its a trans go hardened pind and stuff.And thanx to all who have helped in this stupid situation. General Motors.......This is the worst POS you have ever come up with. But, I like GM anyway.
U haul has all the car trailers you want...-60v6's 2nd Jon M.
I may be bringing a trailer... haven't decided if I want to spend 3 times as much in gas or not...-Brad-
Originally posted by bszopiI may be bringing a trailer... haven't decided if I want to spend 3 times as much in gas or not...If you are driving a Chevy, everything else, is just a blur. 3.4 Carbon Footprint.
But my car looks so good on a trailer!! Besides, my wife and daughter may be coming now after all, and I think I'm still giving Brian a ride as well. So it would be a long, cramped trip in the Beretta... And this will give my wife something to drive if she gets sick of hanging out with all of you guys.-Brad-
