Overdrive won't respond
  • #16
    I've been told quad 4 TCs will bolt right up to a 3100 flywheel and they have a higher stall then a stock 3100 TC... So maybe try that? If someone can verify that they do work. The problem with using the same TC is that the failure could be inside the TC, so if it's out you might as well throw another 1 in.
