284 v. 282
  • 284 v. 282
    what is the difference between thetwo? is the 284 stronger, or have different fdr?
    thanks
    284 is about 50 pounds heavier, and harder to get parts for (impossible nearly). Its stronger, and uses a pull type clutch vs push type for the 282. 3.61 i think is the 284 FDR. Its close ratio as well, similar to the 282 out of the 190hp quads and something else I think. That 282 had a 3.94 as well. brian89gp.com used to have the charts but I dunno if that is still up.
      you don't want that 3.94 FDR! 3500 rpm at 60mph will suck!
      Andy
      fastest 1/8: 10.19@ 67.17
      fastest 1/4: 16.16@ 82.70
        Yes it does!
        that's why i'm swapping the 3.61 FDR into my W41 tranny
          no it's not Dave!! you're swapping cause you went faster in the 1/4!!
          Andy
            haha, i was wondering since i had seen a couple in the jy's before, and didnt know if they were stronger or better, than the 282, and should have taken it. in no way would i put any higher of a fdr in one of these trans!
            thanks for info
            cody
              i found it was more like 2850 at 60mph. however thts with the .81 5th gear, swap in a v6 5th gear (.72) and it drops you to 2450 at 60mph, wich was actualy perfect with my cam i was running.
