Easiest way to remove Axle 2000 W-body
  • Easiest way to remove Axle 2000 W-body
    Whats the easiest way to get the passenger axle out? I untorque the axle, slide off the wheel hub and now what? Remove the tie rod and lower balljoint? should that be it? Thanks a lot guys its cold out here.
    Just undo the lower ball joint. The axle stub should be able to come free of the hub with the tie rod end still attached.
      thank you very much
