just wondering about something. is it easy to swap a 282 into a w-body that had a 284 in it?
will the mount fit? NBD if it doesn't, i can make it fit
would the 4t60e axles plug into a 282?
will i have to swap out the shifter and linkage?
will i have to swap out the slave cylinder? master cylinder?
will the vss work correctly?
would j-body or n-body axles work on a w-body?
reason i was asking is my 284 will die at some point and replacing it will most likely be either difficult or expensive and i am not going back to auto.
lastly, when that fated day comes, i would like to see how my 3.4 dohc would act with one of those 282's with the 3.94 fdr's
provided the bellhousing is the same from a quad4 to a 60v6 of course.
