sythetic tranny fluid?
  • sythetic tranny fluid?
    Has anyone had a problem running sythetic tranny fluid in their transmission? Only reason I ask is cause I can get a good deal on RP and can get their stuff. Im currently using the valvoline maxlife ATF. Any thoughts?
    3400/Getrag 284 5spd
    350/NV3500 5spd
    2014 Chevrolet Malibu LS
    im going to say its not worth it for you. fresh after a rebuild i wouldnt hesitate to run synthetic, however switching over at this point in the transmissions life, you arent going to see the benifits.
    if continue to run what you already are.
