Help Building A 3.73
  • Help Building A 3.73
    Will a 4T60-E code 6CUW out of a Grand-Am with a 2.4L fit into a 97 Grand-am with a 3100. Then if I take the differenial out of the 3100 trans and put it into the 6CUW trans it should give me a 3.73. Are the 2.4L 4t60-E transmissions built the strong as the 3100's? DO the bell housings have the same bolt pattern?
    the bellhousing bolt pattern is different. also the 4 cyl version will be built a little weaker.
      Thanks Sharkey, I 'll have to keep looking for the right trans.
        The 95 Grand Prix GTP's had a 3.43 FDR 4t60-E with the 3.4 DOHC. You'd have to find another diff to get it up to 3.73 though.
        1995 Grand Am SE
          yep also the 95-96 Z34s i had the right trany they just grabed the right diff for me when they did my rebuild. im very happy with my 3.73's
            z34phoenix, what rpm do you turn at 65mph?
            Andy
            fastest 1/8: 10.19@ 67.17
            fastest 1/4: 16.16@ 82.70
