4t60e high stall torque converter
  • 4t60e high stall torque converter
    i heard that if you use a quad four torque converter behind a LQ1 it will give about 3200 stall, both 4t60e's of course. does anyone know if this true?
    68 El camino 454 speed muncie 3.90 posi 12 bolt,
    80 Monza Spyder nasty buick 231/3.8l v6 200-4R 3.73 posi.
    60 Impala 2 door hardtop L79-327 T56 4.11 posi.
    83 wagoneer torque pig AMC 360 hydradrive (gm turbo 400 with stock sb chrysler bellhousing boltpattern) dana 20 transfer case dana 60 front GM 14 bolt rear. 401 in the wokrs
    91 Z34 now has a hm284. and belly pan in the works
    in general using a 4 cyl converter in a v6 will give you a higher stall. ive heard of people using converters from 2.0l ohc, 2.2 ohv, quad 4, even an iron duke.
