Lucus Trans Treatment.. What U Think?
  • Lucus Trans Treatment.. What U Think?
    What do you guys think about the Lucus Trans Treatment?? A Guy on another forum told me to drain my oil, replace the filter and add just regular tranny oil without Lucus.. He said that the Lucus will destory My Tranny.. What do You guys think of this stuff?
    Robert
    New Rebuilt 3100
    New Rebuilt 4T60-E
    Exhaust
    Drilled/Slotted Rotors
    White
    3" Magnaflow Catback
    90 Pontiac Turbo Grand Prix
    5 Speed Swapped
    127,000
    Spec Stage 3 Clutch
    230,000 mile Getrag 282
    Emissions Deleted
    Brand new Engine 1,000 Miles
    Fully Custom Built car
    this goes for any additive, but what these treatments are designed to do is swell the rubber seals up so they will get a better seal in a worn transmission to firm up shifts and stop leaks. they can work for a short time, however it also causes the valve body gaskets to swell up and it can cause small holes to be blocked off and cause big problems. it also causes a lot of grief when overhauling the transmission cause it turns all the gaskets to a glue like paste.
      so what do u say?? should i flush the system?? I am using it in my 89 TGP with 105,231 miles.. i would think with 8 quarts of ATF and 24 oz. of treatment to make 9 quarts i think it is very well dilluted.. I ended up putting in 6 quarts of ATF and 22 oz. of Treatment in my car. It was just a filter and fluid change. so thats 2 quarts of the old still in there.
      Robert
      New Rebuilt 3100
      New Rebuilt 4T60-E
      Exhaust
      White
      5 Speed Swapped
      127,000
      Spec Stage 3 Clutch
      Emissions Deleted
        is the transmission acting up??? if not, no reason to put the stuff in there.
        the 440t4/4t60e holds 10-12L of fluid. a pan drop will drain about 6L out of it, flushing is the only way ot do it all. however if the fluid was in ok shape when drained out, flushing isnt needed.
          i wouldnt flush a tranny w/ over 100K on it.
          91 GTP HM-284 GONE
          96 Special Edition LQ1/4T60E GONE
          98 Spawn of Satan (L67 Regal)
          87 V10 SM-465/Mild 350
          06 Cobalt SS/SC GONE
            Don't use Lucas Products they don't do anything. All those displays at auto zone are garbage. If you use too much of this stuff in your tranny or if you use the engine treatment it will cause the oil viscosity to thin out and what you will end up with is tranny fluid that has the viscosity of water not good. I've tryed it in several different cars this stuff is S%%T. It will cause the engine oil and the tranny fluid to foam up with will thin out your oil and tranny fluid.
              I just added 1 bottle of the trans treatment to the tranny.. First time used in the tranny.. will it be ok?
              Robert
              New Rebuilt 3100
              New Rebuilt 4T60-E
              Exhaust
              White
              5 Speed Swapped
              127,000
              Spec Stage 3 Clutch
              Emissions Deleted
                it will be fine, but its not needed. most people put this stuff in as a "fix" when the tranny is slipping or leaking real bad. now we all know you cant overhaul an engine with a magical bottle of additive, and the same goes for transmissions.
                  lol
                  Robert
                  New Rebuilt 3100
                  New Rebuilt 4T60-E
                  Exhaust
                  White
                  5 Speed Swapped
                  127,000
                  Spec Stage 3 Clutch
                  Emissions Deleted
