Which stall speed?
  • Which stall speed?
    Hey all,
    got a 94 Z24 3.1 with light mods. i plan on doing a 4T65E 3.69 FDR LSD swap. plan on keeping this tranny for a long time. what stall should i get. my current stall is 2500 rpm. future build will involve something with a lopy idle, but not for 3 years or so. want the right converter for the build in the future--cheaper. but then again, when i do build the engine......the converter will be right there. so not so hard to replace. pulls really hard from 2500-4000 rpm. stay stock for now?
    Andy
    fastest 1/8: 10.19@ 67.17
    fastest 1/4: 16.16@ 82.70
    for now, stay with stock. gm built a 3000 stall converter for a 4 cyl th125, it will drop right into your 4t65e. if i could remember what exactly it was out of, you could look through the junkyards and find one.
      i know it's my toy, but still looking for the best mileage i can get. why not get a 2800 stall? i'd rather have new, not a junkyard persuasion. don't want shudder after all that work.
      Andy
        If I remember correctly, I think the 3000 stall was behind the Pontiac 2.0L OHC engine only, not the OHV engines that also were featured in the J-Bodys. But I could be wrong.
          imo, stay stock for now, when you build that motor up, talk to a pro about getting a custom built tq to your spec, he'll ask you a few questions and youll get what you want.
          you will hardly notice the 3k gm stall from what your running now.
          and if you go custom, make sure you get a TCC lockup tq, there so much nicer with the low gearing
          i have 3.73 fdr and i must say im glad i have OD and tcc lock up...
          Drive sounds like second gear
            sounds good. my 97 lumina had the 2800 stall. couldn't tell the diff between the two. thanks guys!
            Andy
              yeah i love my 3.73's part throtle runs feel like near WOT runs before
                if i have the 3.69 FDR and get the 225/50 R15's, that will increase my overall FDR to 3.81. my tire size stock is 24.7 inches in diameter, where the other size is 23.9 or 3.35% smaller. either case, it will be like a good head and cam swap and pretty sure it won't hurt my mileage at all!
                Andy
