4t60e wiring confusion...
  • #16
    Glad to hear it is all working though!
    Thanks!!!
    Those would have been helpful yesterday morning...
    I am heading out to the garage now - it is raining pretty hard this morning, hopefully by the time i button everything up, the rain will have stopped. I will be back with results of driving her as soon as I can!
    Last edited by KlingonFiero; 10-14-2007, 10:47 AM. Reason: cause I cannnot read :)
    • #17
      Well, It will be a few more days before I can let you all know about how the transmission works...
      I have a lot of wires hooked up wrong/poorly.
      So, I pulled out the whole harness and will start redoing it tomorrow evening.
      With a little luck I should get it done by wednesday or thursday...
      • #18
        Getting close to being done with the wiring... The person I had helping me, did a beautiful job of matching up the wires by color. Unfortunately, this is a complete Frankenstein of a car and the wire colors do not truly mean anything...
        And, I cannot believe I missed this:
        The "Transaxle Range Switch" is putting out a 12v signal!!! The ECM I am using is looking for a Ground signal for the 1st and 4th gear signal
        I hope I didn't fry the ECM...
        CNCGuy: I presume your ECM is looking for a 12v signal? or did you use a relay? or ???
        I am thinking about wiring the switch to ground, and then using a relay to reverse the signal to a 12v for the reverse lights.
        That way I only have one extra relay, instead of two... I will be working that little issue out tonight...
        Thanks for everyone's help! Couldn't have done this without without you guys!
        • #19
          Good to hear you are moving along. My ECM is looking for a ground as well so I grounded the common side of the switch. I do not have reverse lights but would use a relay as you said. Not only would it use the least amount of relays, it would also make it more reliable. I would prefer losing my reverse lights over transmission operation in the event of a relay failure.
          MinusOne - 3100 - 4T60E
          '79 MGB - LZ9 - T5
          http://www.tcemotorsports.com
          • #20
            FINALLY! She is on the Road!!!
            Well, just a few months overdue But, it is on the road and driving very well...
            I ended up putting the "ignition" wire for the 7-pin to constant ground instead of hooking it up to a 12v source... This seems to be working very well...
            I drove it quite a bit and she seems to be shifting perfectly!
            I did use a relay to power the Reverse lights. I think it was very much needed in the Fiero - ever try to back up without any lights in a Fiero??? it's bad enough WITH the lights...
            Thanks to everyone for the help!
            Very much appreciated!
            -Don
            • #21
              Congrats Don... glad it is working out. You are passing me up now since I haven't had any time to tune on mine and it is getting cold out. Good work.
              '79 MGB - LZ9 - T5
              • #22
                Thanks!
                I am getting ready to take it on a 30 mile drive in an hour or two... I am finally going to take a Fiero to the Fiero Club Meeting!!!
                I hope that the TCC locks up appropriately...
                I will let you all know.
