TH125 shift kit
  • TH125 shift kit
    Has anyone installed one of these kits? If so, how hard was it and did it make a noticeable difference in the performance of the trans? It just seems that since they are so cheap, that they wouldn't make a big difference. I was looking at the TransGo kit since they seem to be a reputable company, but are there any other brands that are better?
    Thanks,
    Stephen Davis
    89 Z24 Coupe
    87 Z24 Hatchback
    HOME of the 2BadZ24s
    Anyone?
    Stephen Davis
    89 Z24 Coupe
    87 Z24 Hatchback
      If you've never pulled a valve body off of an automatic transmission, it might be a daunting task. I installed the TransGo on my Beretta and managed to some how screw up reverse. The hardest part for me was removing and reinstalling the valve body. The check balls are a PITA. Make sure you use to grease to hold them in their place. Other than that, just make sure everything is clean and the valves are in the same position as before you removed them. As far as performance, the shifts were firmed up a bit but that's about it. If you have any of the problems that the kit corrects, I would definately install the kit.
      1991 Chevy Beretta GT auto
      Rebuilt engine - Crane H260 cam, crane springs and retainers, ported intake and custom WAI.
      Dual rear sway bars, strut tower brace, and poly end-links. I\'ve got reverse now, but she\'s making me sell it
        Thanks,
        Stephen Davis
        89 Z24 Coupe
        87 Z24 Hatchback
