t460E won't downshift to 1st
  • t460E won't downshift to 1st
    I have 1992 z34. The tranny will seem to drop to 1st when the engine is cold or warm. After running it a ways getting it hot it will not drop to 1st at takeoff. If you pull the shifter to 1st at a stop, after it's hot, take off it's in second, at maybe 3000 rpm it will drop all of a sudden and hold 1st till you move the shifter. I don't understand what going on. The modulator valve is getting about 15 in of vaccum, and it's brand new. I also changed filter and fluid. Is it a pcm problem or tranny problem, electrical problem? I hope someone can help! Other than this tranny shifts great in all other gears.
    Whats the fluid line pressure in the trans? I would check that first.
      wierd, id like to know what could be the possible cause, becuase my wifes 99 hyundai accent does that too
      highly doubt its the pcm
        sounds like a soleniod problem... If you put in manual 1 it should stay there till you upshift to manual 2. if that happening then the valvebody and everythingteng else is fine. I';d say the soleniods are in error
        Lorenzo
