Trans cooler
  • Trans cooler
    Anyone running a trans, cooler ? If so how big ?
    Thanks, Don
    93' lumina z34
    And no i cant spell for shit !!!!
    Never make the solution more complicated than the problem
    all auto 3.4 cars have a trans cooler, so does your z34. why would u want another one?
      94+ didn't (unless you actually count the loop in the radiator a cooler).
      donsz34: Your 93 *should* already have an aux cooler.
        i have a 94 DOHC car and i am running a trans cooler and i highley recomend them..... mine is about 10 by 12 inches and about an inch thick
        1994 Cutlass Supreme Convertible 3.4 DOHC
        1969 Oldsmobile 442
        1997 Chevy Tahoe
        http://members.cardomain.com/mperkins442
          I heard the biggest possible would be best, but run it before the rad loop. The loop acts as temp regulator more than any thing. Like if you are in minus 45C temps like me. It will help transfer some heat from the engine to the tranny.
          Lyle
            Exactly what Lyle said.... your tranny needs SOME heat.... but not ALOT. Always, on any vehicle... if it has the loop in the radiator.... run your cooler before the radiator and through it.
            1993 Chevy Lumina Z34; 4T60-E, CATCO 2.5" hi-flo cat, Flowmaster Exh, American Racing Aero Rims, KYB GR-2's
            1999 Tacoma SR5 TRD 3.4V6 4WD, lift, tires, rims, exhaust, couple of tricks
            1962 Buick Electra 225 STOCK... and gonna keep it that way
              Thanks for the info guys
              93' lumina z34
                hmmm..........at my shop we tend to eliminate the radiator. your transmission will generate plenty of heat for itself. don't believe me? plug your cooler lines and watch it hit close to 1000 degrees before the tranny dies. i've seen it happen plenty of times. i have eliminated the radiator cooler on my own car and have a 10-pass tranny cooler. yes it's overkill, but i already had the cooler from a previous V8 project. i have also noticed my coolant temp gauge to sit a lil lower. HEAT is the #1 enemy of the automatic transmission! Improper line Pressure is enemy #2. also, another benefit of elimintaing the radiator when adding a trans cooler, is no fluid transfer from an old and rusted out radiator. if your radiator goes bad, there is a possibility of anti-freeze mixing with trans fluid, which is not a good thing. running a straight trans cooler eliminates this possibility. From everything i've seen as a transmission mechanic, the cooler you keep your tranny, the longer it's life will be.
                1994 Oldsmobile Achieva (2002 3100 SFI)
                Homemade ram-effect CAI
                K&N cylinder filter
                Poorboy Lowering Kit
                Front STB
