auto stick 282 swap
  • auto stick 282 swap
    ok Its a 95 achieva, go figure, she's got a 2004 3.4 pushrod motor in her. I'm about to put the getrag 282 in her. Which motor mounts/tranny mounts do I look for? Axles? Shifter? Cables? oh here's the few big ones, clutch master and slave? and the biggest, flywheel, and clutch? I want a 4-6 puck sprung and do I ned to have my crank cut for a pilot bearing?
    Ben, this is the Olds guy from St. Croix, I was running a Z-34 there? Anywho, email me for my new number, I'm about to take a 20k loan out to build my olds, and I want you to do the whole upper end. Seriously. I want aggressive cam, 3.5 heads and intakes, full port and polish, biggest TB you got, and I will need your tech help on the obd2 swap too. Finally I got money to use the slogan of money talks and BS walks, so I'm not BS'in anymore, help me spend it Ben!
