Detent shaft through to transmission?
  • Detent shaft through to transmission?
    I recently dropped a bolt through the detent cable shaft... While trying to install a new transmission. I can't see the bolt down the shaft, and I was wondering, does the detent shaft go through to the transmission on a 92 4T60? I'm about to go outside and take off the tranny pan, I needed to change the fluid and filter anyways.
