4T60E ('93) - Input end play clearance question
  • 4T60E ('93) - Input end play clearance question
    Greetings,
    I'm rebuilding a '93 4T60E in a Le Sabre and have a few clearance questions. This unit wiped out number of hard parts after an output shaft bearing disintegrated and the planets in the input & reaction carriers ground the needle bearings into oblivion. As for hard parts, I had to replace the front & rear planets, sun gear & spacer, input/3rd clutch housing and 4th clutch hub/shaft.
    Upon reassembly, I got as far in the stack-up as installing the driven sprocket support, and was surprised to see how far it was below the case surface. I measured .114.
    I realize it's supposed to be "slightly" below (.006 -.012), but not .114! I pulled everything out and re-reconfirmed that all thrust washers/bearings were installed and oriented correctly, and that the selective washer (a blue one, measuring .140) was present under the input/3rd clutch thrust bearing. To my knowledge, .200 is the largest selective washer available, and even if I used the largest one, I'd still wind up with the driven sprocket support ~.054 too low.
    I began to wonder if the replacement hard parts I installed were the cause. I measured everything and find no more than .012 difference between old and new, which could (should?) easily be compensated for by using a different selective washer (I would think).
    But, I *will* say that the origional stack-up included a mix of 1st & 2nd design components, which I wasn't able to find replacements for on a 1-for-1 basis. It originaly had a 2nd-design input carrier/front planet (no shoulder or bushing on top), and a 1st-design 4th clutch hub/shaft (no outer bearing surface on the splined end)
    I was able to find both styles of input carrier/front planets, but only a 2nd-design 4th clutch hub/shaft. I didn't think that should be a problem because I *thought* they were backward-compatible with earlier models. As for the reaction carrier/rear planet, I believe they're all the same, right? The replacement input/3rd housing looks identical, as does the rear planet, sun gear, and spacer.
    I tried assembling everything with a few different combinations of input carriers, but between the two, there was only about .021 difference in clearance between the driven sprocket support and the case surface when assembled.
    To me, it almost seems like the 1-2 roller clutch sits too low in the case. There's about .065 between bottom of the snap-ring and the top of the drum surface. Does the input clearance tighten up only when the final drive and output shaft are installed? I haven't installed those yet because I was worried when I saw so much clearance up top, and I'd hate to crack the channel-plate and obviously can't leave this much endplay.
    Has anyone here encountered this before? Is it possible that I was given wrong planets, perhaps from a 440? (I don't even know if they're the same).
    Any information/suggestions/feedback, etc is *sincerely* appreciated. Thanks in advance!
    --mike
    Well first a 93 4t60e didn't exist... I think... I thought those were just 4t60's... Non electronic. I could be wrong.
    But to answer your question I had alot of endplay when I built my 94, I measured almost twice what they said but I just went with it and its been running fine. One question, you do have preload on the carrier pushing your Final drive ring to take up all the slop there right?? Thats the only thing I can think of.
      91-93 3.4 DOHC got the 4T60-E.
        Huh?
        Hi Sappy --- Thanks for the reply, but you lost me (easily done, lol) I'm trying to understand your post as related to my question. Did you accidently reply to the wrong post?
          lol i think hes saying....
          do you have the dohc 3.4
          becuase only the 3.4 came with the 4t60-e
          but then again i have no clue what the le sabre came with for motor trans options
            He was replying to my post... I was un aware of the 91-93 coming with a 4t60E
              Hi,
              Thanks for the reply. Oh it's a 4T60E alright. Yeah... they were definately around in '93 (even as far back as '91):
              I guess I should have mentioned that I'm not a novice at this. Used to do it for a living, but that was a *long* time ago, and this particular transaxle didn't even exist back then. This is my first 4T60E rebuild though, which is why I'm being extra cautious. Nevertheless, I think I found my answer. Here's how the clearance was (.114") when I posted my question:
              But, after installing the final drive, output shaft and extension housing, (and pre-loading it) the clearance dropped to .028":
              I realize that since this is input shaft endplay, and not final drive endplay, that it's not likely to destroy itself as a result. There'd probably just be a more noticable "clunk" going from neutral to forward gears, but I'd still like to see it closer to .010". I just worry about breaking the channel-plate knowing that it has to "bend down" .028" on the driven-sprocket side when torqued into place. Time for another selective service washer I guess...
              Anyway..... mystery solved. Perhaps this post can be of value to someone else rebuilding a 4T60E for the first time.
              Thanks again.
              --mike
                that is odd, i swear your post wasnt there when i went to reply
                lol...my brain is not functioning today :P
                  It wasn't there... I'm no sure why, but the post was listed as unapproved, so only moderaters could see it. I approved it after several of the posts were made. Sorry for the confusion.
