HM282 team green lsd install part 1
  • HM282 team green lsd install part 1
    hey guys i got the tranny out and i have a few days til i get the lsd so i figured i would do a little write up...
    now you guys are on your own as far as removing the tranny..
    step 1 remove the tranny
    with a clean work bench start tranny disassembly
    slam a screwdriver or pry bar into the cover above and pry it out.. THIS COVER MUST BE REPLACED
    picture of the detent assembly with the cover removed
    now remove the two 10mm bolts that hold down the detent assembly..
    there are four balls and springs in there DO NOT LOSE THEM
    detent assembly removed here you can see the reverse detent bushing(must be removed next step)
    these are my tools of choice to remove the bushing
    how i used them to gently pry out the bushing
    reverse bushing removed
    bushing removed
    remove the vss bolt and clamp 8mm
    pull the vss out of the transmission case
    remove the shifter assembly (this step doesnt have to be done but i did it anyway)
    shifter assembly removed and reverse light switch removed
      now remove all the case half bolts all 13mm
      remove this bolt with a 13mm wrench so you dont have to remove the shift shaft cover
      flip the tranny clutch housing up
      no lift off the clutch housing half
      clutch housing case half removed just pick up the differential to remove it
      differential removed
      more steps to be added as soon as the lsd actually gets here
        id like to note that you do not have to replace the detent cover if you get in on the edge and lightly pry it out. you bend the lip, but it is easily straightened then reasembled with silicone. ive done this several times.
          cool didnt care to take the time... i get those covers cheap through gm.. thanks for the input though
            another thought, if your going this far to pull it apart, you may aswell pick up a complete seal kit and reseal it, even if its not leaking. stop the problem before it starts.
              Oh sweet. Mine needs a rebuild, but I'm not confident at all when it comes to transmissions. At least I can learn from what you're doing. If I had a spare one I'd rip into it though.
              So far so good. Pics really help too.
              1990 Chevrolet Beretta GT *new project*
              1990 Pontiac Tempest LE *GONE* ~formally 3400/5-speed equipped~
                The dif look more robust than I thought it was.
                  i agree, when i did the gearswap i didnt put enough RTV down, and it leaks every now and then
                  [SIGPIC]
                  12.268@117... 11's to come!
                    excellent info!
                    i'll be doing this in a month or so.
                      there is actualy no gasket for between the cases, it is silicone from the factory. the seal kit includes the axles seals, front seal, shifter seal, detent cover plug and a new o-ring for the reverse light switch. for the little bit of money it it, is well worth it.
                        how much was this team green and is there more info!!??
                        [SIGPIC]
                          i paid 215 for it....
                          His name is Brian Wisniewski,
                          email wizzer03@hotmail.com
                          tell him what trans you are using, i'm sure he has an LSD for what you need.
                          Part cost is $215 shipped to US
                            did you ever finish this swap? do you have any more pics? i want to do this to my 282 in my grand am and i also want to lower the gear ratio so it revs lower at cruising speeds.
                            Jake
                              im having a helluva time finding a part number or listing for the detent holder cover. does anyone have the part number? also for the shift shaft cover seal?
                              part number for the detent holder cover is 14082039. should be the same for 282/284
                              91 GTP HM-284 GONE
                              96 Special Edition LQ1/4T60E GONE
                              98 Spawn of Satan (L67 Regal)
                              87 V10 SM-465/Mild 350
                              06 Cobalt SS/SC GONE
