High-flow cats
  • High-flow cats
    Where's the best place to buy the most inexpensive hi-flow, direct bolt-on cats for a Z-34 Lumina?
    1989 Corvette L-98
    Rebuilt 700-R4 with 2200 RPM stall lock-up Torque Converter
    Hedman LT Headers
    Dynomax Exhaust
    Cross-Drilled and Slotted Rotors
    Accel Ignition
    Bilstein Shocks
    Line-Lock
    Edelbrock Valve Covers
    Smog Pump and Cats removed
    K&N Air Filter
    1993 Lumina Z-34
    83,000 Miles
    Stock, for now.
    google.com for 2.5" high flow cat.
      Direct bolt on high flow cats? That's going to be quite hard to find. Magnaflow/CarSound make some good high flow cats. A test pipe will make more power, but is not emissions legal.
      Tim
      325 whp 350 lb-ft
        Tim
        Well, actually, the car just got inspected, and just barely passed emissions. Plus, the engine temp goes up the faster you go; highway speed. The stock cat is clogged. I was thinking of a hi-flow cat, but I also thought about getting rid of the cat altogether by putting a straight pipe there for now.
        1989 Corvette L-98
        Hedman LT Headers
        Dynomax Exhaust
        Accel Ignition
        Bilstein Shocks
        Line-Lock
        K&N Air Filter
        1993 Lumina Z-34
        83,000 Miles
        Stock, for now.
          catco are cheap and flow pretty well. You'll likely have to weld or cut off and clamp it on.
