std trans rear cailper same as auto trans rear ?
  • Question : std trans rear cailper same as auto trans rear ?
    Is the standard transmission and automatic transmission rear calipers the same?
    What's a transmission rear caliper?
      It's different per model not trans. You should have the smaller brakes.
        I do not know why rockauto.com has the rear calipers with standard transmission and then rear calipers with automatic transmission.
        AUTOSPECIALTY / KELSEY-HAYES Part # 4182523 Brake Pads Not Included; Remanufactured One of our most popular parts
        R Right Reb Caliper 1 3/8" - w/MAN TRANS; Base Model [Wholesaler Closeout -- 30 Day Warranty]
        Part Image
        CAD$33.60 CAD$0.00 CAD$33.60
        AUTOSPECIALTY / KELSEY-HAYES Part # 4182527 Brake Pads Not Included; Remanufactured
        R Right Reb Caliper 1 3/8" - w/AUTO TRANS; Base Model [Wholesaler Closeout -- 30 Day Warranty] (Only 5 Remaining)
        Part Image
        CAD$36.75 CAD$0.00 CAD$36.75
          Can you contain any of this in one thread or at least post in the correct forums for some of the issues? This Pushrod Maintenance... there is a forum for brakes, transmissions, etc.
          Sigh. Start a thread called 'packardbell's myriad of car troubles' and post everything in there. You don't need to start a new thread for every minutia of your repair attempts.
          - Ben
            Sorry... didn't mean to be a dick.
            - Ben
              parts arrived today, will get a early morning start to get this done asap.
                okay the standard and auto rear calipers seems to be the same and identical. only difference is the bushings and seals for the two long bolts to mount.
                the standard one using a rubber sleeve into the two holes with an exposed metal cylinder, while the auto one has these rubber seals that covers the sleeves.
                  got a hiccup trying to transfer the parking brake lever and bracket on the drivers side. Got the 17mm nut off but the T40 torx got rounded.
