Hub Centric ring size?
  • Hub Centric ring size?
    Ok i just bought Motegi DP10 (17x7) wheels for my beretta z26,
    They didnt come with centrichub rings and i would like to have them..
    Does anyone know the EXACT size rings i would need?
    I would need the Inner diameter size which would be the wheel bearing hub size
    I would need the Outer diameter size which would be the wheel bore size
    I hear if they are sloppy than its not even worth getting them so i need exact dimensions.
    If anyone has them lmk thanx!
    Try rockauto, and look for hub and brake rotors. Sometimes they have dimensions listed. Timkem and Centric will also list dimensions.
    Assuming you still have the tapered wheel nuts they do nothing for you. The lugs locate and support the wheel. If they do cure a mystery vibration, then the wheel studs are out of center and the ring is then putting the studs and nuts in a bind.
    Dan
    http://www.zrracing.com/
    [/url]http://www.youtube.com/user/zrracing4
      found em
