99 seized motor
  • 99 seized motor
    hi new to the sight, have a few questions. i have a 99 grand am gt, has a seized motor. my question is if i wanted to put a newer style 3400 into it what is involved?? havin a little trouble findin a 99 motor, and would like to upgrade to somthin newer anyways. also if i did upgrade the motor what about the tranny?? thanks any help is appreciated
    thanks
    drew
    outta curiosity, what siezed the motor?
    I think there's some differences using the late '00+ 3400's with the GA's PCM; mostly because of the m2 injectors, different FPR and pump design, and stiffer EVAP regulations. There's also some other designs that called for changes in the BCM's programming, and may have an influence on the PCM also (if you went with a newer motor and PCM).
    As far as I know, there were no changes to the tranny between '99 and '05 (except for internal solenoid differences), but nothing that impact the PCM's control over it, no matter what the year. All 5th gen a/t models used the 4T45-E tranny, as did the Alero.
    N-body enthusiast:
    {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
    {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
    Current Project:
    {'90 Chevrolet C1500 Sport 350TBI}
      The EGR changed but it should work as far as the wiring/connector goes for 2000+. You could swap your injectors but it would be better to get a DHP powertunr and start with an 00+ code (or copy the fueling stuff if need be). The 3500 swap would require a bit more work but would be a better option over the 3400. Have to deal with the FPR right now (working on a swap kit now), and the crank position sensor setup.
        Funny that you should ask....
        I have a 3400 motor out of a 99 Grand Am. 80k miles on it and it was running perfect. I bought it for my 95 Lumina, but have since decided to step it up to a 3500 DOHC and 6speed setup.
        Where are you located? I'm near Chicago....
        Make me a reasonable offer.....
        Thanks!
        Larry
          lkurek
          interested in the motor, i am lookin for one locally but am havin trouble findin one of the same year. but if i cant then i think we can work somthin out. thanks
          drew
          prophiseer
          thanks for the info, i have no idea what seized the motor. kind of a lucky story. ran into a old friend that i havent talked to in years, and he said sumthin about havin a grand am. so i go check it out and the car is beautiful. been sittin for a year so its just dirty. been havin problems tryin to figure out what was needed to swap a new motor. im not really tryin to get myself into a huge project here so im glad i didint just buy a new motor. got the car for a steal, tryin to keep everything cheap.thanks
          drew
