reverse rotation?
  • #16
    Originally posted by RebelGT
    Originally posted by RednBlackCutlass
    With all the work needed to find and install a counter-clockwise engine, wouldn't it be easier to have new gears machined for the differential, to change rotation to a clockwise engine?
    Leaves a lot more options...
    Either way he's going to have to make adapters for the engine to mate up the trans of his car, so thats not a big deal. Picking up a used boat engine would be the quick fix.
    QFT!
    Also, thr tranny would still be ran in reverse direction from it's intended direction with a forward rotating engine. Confused yet?
    So that could cause lubrication and wear issues.
    Reverse rotation engine would be easiest.
    *Wacky idea*, Using a gear set, sort of like an inboard race boat V-drive, just that the output shaft still runs away from the engine, and use that for the input to the tranny.
    • #17
      *Wacky idea*, Using a gear set, sort of like an inboard race boat V-drive, just that the output shaft still runs away from the engine, and use that for the input to the tranny. [/quote]
      That might not be so wacky.
      • #18
        Maybe some more info on a Citroen? Not too familiar with it. I heard it can run on 3 wheels. That's about it.
        • #19
          Not anymore
