Question on a engine swap?
  • Question on a engine swap?
    Replacing my dead 3100 ,its a '94 car and I?ve come across a '96 3100 that I'd replace it with. I know I?ll have EGR issues-(Either need to block off or get adaptor plate).
    So my question is: Can I use the intake off the '94 thus solving the EGR situation. If not where can I get an adaptor plate or how can I reprogram the computer to ignore the EGR block off.
    Just want to know the simplest way to make this swap work.
    RE: Question on a engine swap?
    yes you can use the older plenum on the newer engine. if you havent spent the money yet, you may want to look into a 3400 however. they can commonly be had for the same cost as a 3100 and are a direct swap in. Not bad for 20 more HP out of something you have todo anyway
    1995 Monte Carlo LS
    3400 SFI 60v6
