ALDL wiring OBDII
  • ALDL wiring OBDII
    I have a 99 3400 out of a Montana in a desert pre-run buggy.
    How do I wire my ALDL connector to the PCM?
    The connector has four wires. Purple wire on #2 pin, black on #4 and #5 pins, and orange on # 16.
    The pcm has a purple wire at c1-59 and a tan wire at c1-15.
    My chilton manual says the plug should be wired different.
    Also, how do I wire an autometer tach?
    I have the white wire that exits the PCM at pin c2-8, but it does not work. Do I need a tach adapter from msd or something?
    Thanks for any and all help.
    Frank
    RE: ALDL wiring OBDII
    to get tach reading you need to tap into, i believe, the white wire in one of the connectors that plug into the ICM mounted underneath the coil packs.
    1994 Oldsmobile Achieva (2002 3100 SFI)
    Homemade ram-effect CAI
    K&N cylinder filter
    Poorboy Lowering Kit
    Front STB
