Need fuel pump recommendation
  • Need fuel pump recommendation
    I completed a 3.1L V6 swap into my Opel Gt about 18 years ago and I need to replace the inline fuel pump which has gone bad. What recommendations would anyone have for a new inline pump suitable for the 3.1L EFI engine? Thanks!
    Anyone have advice?
      I've been using a Walbro 255L/hr on my car for about 7 years now.
        Thank you James! Looks like stock fuel pump specs from the 1992 Camaro engine are static pressure of 80-130 psi and flow rate of 18 gph or 68 lph. I know fuel pressure is set by the regulator and not the pump so using a pump like the Walbro 255lph obviously works. Since my engine is pretty much stock except for eliminating the extras such as AC, EGR, etc., do you think the Walbro GS394 pump would be adequate. Has the same typical and max pressures of 43.5 and 87 but a lower flow rate of 190 lph. That's almost triple the required flow rate and Walbro says the pump is good up to 500 hp engines.
