I have a 1989 Beretta with a 2.8 (generation II) that has given up the ghost. I found a 1993, 3.1 (generation II) to replace it with. It appears to be exactly the same except for the slightly larger displacement.
If someone has made this swap could tell me if you had to change anything other than the engine? Also, will I have any problems with the old 2.8 ECM working with the 3.1?
Any help information that you have would be greatly appreciated!
Thanks,
Doug
Thanks,
Doug
