For you guys looking to swap your 3400's into RWD. Don't forget to pull the coolant temp wires back out of the injector loom and lay them towards the front of the engine. That way when you swap your intakes around and put your injectors back in, the wires will be poking out the right end. Alittle something that I just realized I DIDN'T do about an hour ago.................Quintin
